I know there are lots of threads out there and I promise you I've gone deep down the rabbit hole, but I'm trying to find out if I'm going in the right direction for my symptoms.
2014 Trial Premium with 105k miles.
Started to experience a clunking in the front end that's mildly evident when going over bumps and VERY prominent once I get on gravel or off-road. So much so that I have zero desire to take the truck off of the pavement. I've taken it by three different mechanics and all say that nothing is wrong. Finally found one that thought it could be a worn LCA so we started down that route, but it has not solved the issue.
In the past week I've had the following done, and while the truck rides a bit smoother on the pavement it still feels awful on gravel. Steering feels loose and clunky:
-replaced both LCA
-checked LCA cam bolt torque
-replaced front sway bar bushings
-installed new tires
My current thinking is that the problem could be the intermediate steering shaft u-joint issue, but I cannot find anyone referencing the same symptoms. All threads mention steering issues on pavement lock to lock (which I dont have) and don't discuss off road driving.
Anyone else experience similar symptoms? Does this sound like it could be the issue?
-replaced both LCA
