Ideas for a shorter antenna?
Will FJ Cruiser antennas fit on the 4runner? Looking to buy the 8"-13" from mangowalk or stubbyantenna, they look the same...
Guys, I went to Autozone yesterday and found a $6.95 antenna that had several different combination studs and one was the right size and long enough for Mangowalk 3" or 5" antenna and T4R female receiver. The antenna that came with the studs looked really cheap, but the selected stud was a perfect fit. The antenna was Metra/RoadWorks Replacement Antenna Rubber Mast #AW-RM1R Universal. I just tried it and the reception of local and near local stations seems to be as good as the original antenna. Distant stations not as good as the original. For me, based on where I live and where I go, it is perfect! If you get this, be sure to remove the the very thin plastic from around the threads of the stud before lubricating and screwing it in. Hope this helps!
This was the solution in 2010. If they still haven't made an adaptor for the 4Runner, you might have to contact them to find out if they have one by now or do the Autozone "fix."
BTW: I'm still mulling over getting the Pep Boy's antenna instead of the other ones ;) I listen to 106.7 The Junkies a lot and I'd hate to lose reception and not hear them in the mornings and Lavarr and Dukes in the evenings.
Just picked up a Pep Boy's Pilot antenna ANT-029B (thanks ktn419 for the idea) and stuck it on, took about 30 seconds. Like some others, between the XM radio and ipod dock, I never listen to FM/AM...so I'm not really sure how the reception compares.
I got mine from the same place as D-ride, Universal 14" rubber stubby. I did not like the short ones, reception is still good.
Bad picture from my phone
Same as you, I am a XM radio, ipod person, so no need for local FM/AM
I have the same and works great, when I am listening to AM/FM. I too, spend most of my time on XM.
Also, mine has bent back towards the windshield. Probably from all the highway driving I do.
Just got the Pep Boys Pilot antenna ANT-029B antenna. Reception seems to be good in the DC metro area. It's a lot shorter than I originally thought...LOL. I'll post pictures soon.
The following stations didn't seem to have any issues with reception so far.
FM: 99.5, 106.7, 107.3, 97.1, 103.5, and 94.7
I'll post more as I drive around the city :)
Update: 99.5 has some very slight signal degradation around portions of NW DC but its still mostly clear. Not bad for $12.
I wanted to add on this thread. I replaced my stock antenna with the same one I have seen on this thread from Pep-Boys (the short little black one). I was washing my car the other day and I accidentally bumped it with my elbow. I thought the whole thing was going to break off at the bracket.
My point: This thing doesn't have any give at all and the plastic piece that holds it onto the fender is pretty week. It wouldn't take much to break everything off if you were to hit a thick branch or something.
I am going to keep it on there for now, but I am looking for a similar sized rubber one.
Could someone explain me why some models don't have an screwable antenna? like mine.
I think you mean threaded antenna not "screwable antenna". 4ths Gens like yours have them embedded in the windshield glass.
screwable : what the Toyota bean counters thought 5th gen owners would be going back to a mast antenna. :bigok:
Here's pics of my new "go big or stay home" mast antenna.
2ft Firestik II with HD spring and adapter .....still need wire it up and work out the bugs and made need the Antman!
Supposed to work for CB and AM/FM with this...... AR-1A
Got the idea and bought the adapter from a guy on the FJ forum.
About an inch or so shorter then the oem mast and clears my garage door.
Picture036-3.jpg~original
Picture035-3.jpg~original
I like this set-up, please keep us updated!
Pilot Antenna update and a question
Hey guys, hope this isn't resurrecting a thread too old, just figured the information was still somewhat relevant and had a question of my own.
First of all, just installed the Pilot antenna from Pep Boys we have seen on this thread before. Installation was a snap, sorry about the poor photo quality but attached some pics to show the process and what is included, you can see the OEM antenna laid down next to the original to show the proper fitting.
No feedback on the reception quality yet, as most others have stated I only have minimal time spent listening to FM these days, but it blends right in with the base and looks great.
My question, that has been posed (but not answered) previously is: have we ever decided if there is a type of lubricant that will / will not affect reception quality? Would definitely like to put something in there to help its longetivity, just don't want to affect functionality too much. Thanks!
Interested in this as well. Would have thought by now there would be some kind of plain button or cap with a threaded stub attached to it you could just screw in place of the original antenna / mast.
Finally pulled my Pioneer Nav out yesterday and hooked up the Firestick AR-1A splitter for my Cobra 75 CB and tuned with my SWR . Much to my surprise I'm picking up AM/FM and CB thru the same antenna with great reception!:naughty:
Here is how the splitter looks with the extra adapters.
FireStickAntennaSplitter-2.jpg~original
Wanted to do the same thing for long time, just not sure how to start and how to pull the radio : )
So how did you ground Firestick antenna?
Is there a good space to put splitter behind the stock radio or you put it somewhere else ?
I just followed the lead of others on the FJ forum. Firestik II as FM antenna - Toyota FJ Cruiser Forum
There is room in the center shifter console after you pull it up and I just ran the leads up from there. That's where I Had the box for my Cobra 75 anyways. My Limited has the electronic 4x4 selector so alot more room then yours under there but you should still be able to squeeze it in as it's not that big.
Used the repair manual to remove my radio the first time.
Here's a novel idea, all antennas in one; AM/FM/XM.
VW uses it on their Passat and the part number is 1k0-035-501C.
Who's going to be the first to install this nifty mod?
I've read that thread on FJ forum, but I didn't find much about splitter there. Seems to be quite straight forward, the only thing I'm not sure about is how to ground Firestick antenna. I'm not sure if factory mount is grounded properly. Did you do anything special for grounding or just screwed antenna in the stock mount using Nestor's adaptor and connected cables to the splitter?
lindwlson982
