Cornfed rear coil spring spacers or Truxxx spacers?
sporty87
I Need rear coil spring spacers for my 2010 SR5 4Runner and I only need about 1" of lift. Does anyone know about or have any experience with Cornfed Suspension spacers which are made from UHMW which is a type of plastic and can be made in any custom size or the Truxxx rear coil spring spacer which is I believe is metal and the smallest size comes in 1.250" length?
Also does either the UHMW or metal spacers have any advantage over the other one such as quietness or longevity?
I raised the front up with the Bilstein 5100 adjustable shocks set at 1.750" and it looks level but if you look at the rocker panels it now sits low in the rear.
Thanks
