Rear hatch problem
Gstick
For some reason, my rear hatch will not open up. This is on a 2010 SR5, 4x4. I washed the truck the other day, and I wiped down all the door jambs including the rear hatch. Did I bump some kind of switch on the hatch door jamb, or somewhere else? Is there an interior switch somewhere that I may have bumped ? Please help!
Fuse Check?
Have you checked your fuses yet?
According to the owners manual, the fuse for the back door is #10 under the dash (drivers side) It is a 30 amp, and I checked all of the 30 amp fuses, and they all are good. I also tried the window lock on the drivers door, and it did nothing.
There is a clicking sound coming from the fuse block area (under the dash, drivers side) every time I try to open the back door. Could this be some type of relay gone bad ?
I assume you are still under warrenty.....it is stealer time! Please let us all know what happened just in case......
Try this link. No pictures, but might be a starting point.
http://www.toyota-4runner.org/5th-gen-t4rs/68776-electronic-rear-hatch-if-power-out.html
Did you use any product to wipe down the door jams & hatch? If so, that could cause it to stick to the rubber seals. Happened to me, just have to use a little bit more umf (muscle).
I just wiped down the jambs with a damp towel. There is defineately something wrong, electricaly. Like I said before, when I squeeze on the rubber part of the back door handle, there is a clicking sound coming from under the drivers side fuse block. (under the dash) I am calling the dealer today.
search for "tailgate on the fritz"...mine ended up being a broken wire in that harness that you called a rubber thing. Yours could be the same...
be careful, dealer would have misdiagnosed twice had it not been for the forum and someone in Canada having the same issue first :-)
I felt lucky to have only visited dealer for one misdiagnosis and one repair visit.
Dropped off my 4R this morning at the dealer, and they called with the news that the rear hatch (door) opening mechanism shorted out. They will have the new part tomorrow, and complete the repair job under warranty.
Premium audio package supports required
Have a 2013 Limited and the lifts/supports have failed (55K miles). Has anyone had experience with this? NAPA sells a support rated at 216 lbs but nobody's sure if this will work. Premium audio seems to add extra weight and stress. Looking for reasonable priced replacement.
4Runna4Rumma
