Engine Rebuild Cost
Nodd
I've come to the conclusion that my 3.slow engine is in need of a rebuild. It runs okay but is utterly lacking in power. Little old ladies pass me on the highway. So to that end I'm considering buying this kit...
engnbldr.com TOYOTA 3.0 V-6
I've seen several threads here pointing to those guys & the price seems pretty reasonable. Although I rebuilt an engine with my Father when I was a teenager, I'm not planning to do the work my self. Mainly because I don't have a garage anymore but also because I'd like the engine to actually work after its back together.
What I was wondering is, does anyone have an idea how much I should expect to pay a mechanic to do the rebuild?
There's too many variables to give a realistic estimate over the web.
Also, unless you find the right place, no shop is going to supply much of a warranty unless they supply the parts.
Well I'd be interested in a mechanic installing the parts in that link. Perhaps a better question might be... how many hours might that take? I realize mechanics charge different rates.
Hadn't considered the warranty issue. Always seem to own old used stuff, haven't had much experience with them.
Also, who is pulling/reinstalling the engine, you or the shop, that's a big chunk of $.
The mechanic.
Again, hard to answer.
Does the block need work ? (boring the cylinders, etc)
Does the heads need worK ? or are you installing new, built heads.
Rebuilding an engine is way more than just installing new parts.
Have you looked into a remanufactured engine?
Yes I've looked at crate/rebuilt engines. They seem to range from $1300-2000.
What I'm hoping here is that someone might give me a rough ball park figure on how much a rebuild might cost as opposed to replacing the engine. I don't want to proceed with either option until I have a clue what I'm getting into cost wise.
Any non-do-it-your-self-types out there recall what you spent having your engine rebuilt?
AnhD
