COM10T or FKS10T spherical bearings
Johnson51
I just had a spherical bearing on my coil-over go out while in Peru. I was able to source a COM10T which is the standard bearing on most coil-over shocks. My question is weather on not I would be able to use the FKS10T bearing that at in King shocks when I get the runner back to the states in a few months. I wouldn't have a problem using the COM10T, but the FKS10T is made to withstand a bit more. Has anyone tried to use one over the other since the size be same?
Thanks and greetings from Peru
