Will i be able to power this system?
gurman13o
I have a 1000Watt Lightning Audio Amp
and a 15 inch MTX thunder 5500 Subwoofer
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1590778/vpcsid/0/SFV/30046
thats information on the subwoofer
Brand: MTX
Condition: New
Frequency Response: 19-150Hz
Magnet Weight: 81 oz
Efficiency: 93.6
Impedance: Dual 4 Ohm
RMS Power Handling: 150-300 watts
Peak Power Handling: 600 Watts
Mounting Depth: 7.576 Inches
and my Amp is
http://www.lightningaudio.com/scrip...-xJxFZi&p_tbl=9&p_id=137&p_created=1154120625
Number of Channels:
4 Ohm Power @ 1% THD+N:
2 Ohm Power @ 1% THD+N:
Input Sensitivity:
Power Connector:
Frequency Response:
Subsonic Filter:
Signal to Noise Ratio:
Crossover LP:
Crossover Slope:
Pass Through Output:
LA Power Cell Connector:
LA Fan Connector:
LA Lighted Logo Connector:
Juice Boost EQ @ 45Hz:
Specifications subject to change without notice
Mono AmplifierS
Storm S1.1000D
1
600
1000
130mV
Your all set, that one amp wont overdraw your electrical system.
The 4Runner factory equipment is actually pretty strong.
The 4GA wire will be fine, make sure to fuse it.
You also will not be using 1000w rms anyway....your subwoofer is only rated for a third the power that amp is rated for.
So yes, your 4runner can handle all of that.
