Help JBL Crap
4Runna
trying to understand this as best as i can...
ripping out head unit, using a pc...
1. if the head unit is removed, does that amp in the jbl 10 speaker system still get power? how do i ensure its off otehrwise?
2. if i want to use the factory radio antenna sometime in the future - how would i go about it?
3. what is that "junction box" or whatever with 2 of the rear speakers on the wiring diagram that is circulating???
you can still use the speakers you just have to figure out what color matches up to your aftermarket stereo. as for the amp you would be better to just go buy an amp and a sub. be done with that JBL crap.
you may want to check out 12volt.com for a wiring diagram, i dont know if they would have one ye but its worth a shot.
thank you for the reply.
what you brought up i already know... jbl is hard to integrate with and not worth it, so i am going to remove the amp... my question is if i dont remove it, will it still receive power w/the headunit not in place...
the wiring diagrams are here , i know what to remove...
