Significant drop in milages since fuel filter change
gumbii
So the title says it all. A few months ago I decided to replace the fuel filter on my 02 4runner, as its the original and the vehicle is approaching 200k. Swap itself seemed pretty straight through and easy. However, since then Iv noticed a significant drop in my mileage. I used to get 300-320 miles per tank before the light came on. Im now only pulling around 270. At first I thought that it might just be a computer issue, with the system having been used to the a dirty filter, however after the last few fill ups, Iv noticed Im still putting 16 gallons (Light always comes on with about one gallon left). Best I can tell, changing out the fuel filter has lost me 30-45 miles per tank? Iv had a mechanic take a look at it while doing other maintenance. Not a full inspection, more of a cursory to make sure I didnt hook it up wrong or have a leak. No issues, at least from the install side. Has anyone experienced this before, or have any ideas?
Also, this is the first of 2 different threads on my DIY maint issues. Not spamming, just have not had much time recently.
You may have a very small leak. I had the same problem a long time ago on a Honda Accord, couldn't figure it out at first, but with just the right conditions it would leak, but not all the time.
Any tips on how to spot and fix it? If it's just evaporating is there a way to spot where?
Just keep checking under the hood any chance you get, and keep checking for a gas smell.
Might not hurt to remove it and make sure the threads are clean.
A misplace rag or plastic bag could be doing the same thing as a clogged air filter. I mean Check all from intake point to the throttle body
patnewton
