'03 & '06 Retrofit Satoshi Grille Writeup (Picture Heavy)
Hey Matt, would you recommend fiberglass cloth or fiberglass thread stuff? I have worked with the loose stuff and I like the results, but I don't know of the cloth is even stronger or whatever.
Thanks in advance
Thanks in advance
Did you get rid of the metal bracket in the back?
No it's going back in when I trim it, but my issue is the huge gaps I have now
I made those metal brackets to hold the lower piece on and I'm very glad with how easy of a fix it was!
Black plastic
I'm removing this black piece of plastic. That's all that is in the way. When I trim the bottom corners it should sit on the bumper just about.
So as I understood you completely removed this black filler
Is it mounted by the plastic pins like side moldings? If you have any pictures of the bumper with removed filler - will very appreciate!
It looks like crap without the filler piece but whatever.
It has weird clips you have to access from underneath the bumper... Or do what I did, rip the damn thing out. I'm not using it again, so why not?
Those clips are a PITA to get off... I ended up breaking a couple and maintaining a couple. I little loose on there now, but its still fairly solid.
thanks!
emelianenkov as I see you are doing this thing for same purpose - to mount the addtinal light))
I will mount high beam projector hella 4000
p.s. do you speak russian
thanks!
Well I did the satoshi for both looks and functionality. Putting a 22" bar behind it soon!!!!
What makes you think I speak Russian?
Only your nickname ))
Yes LED bar will be a good choice - as there will be more light and less heat. The only con - there will be no any cover similar to hella light
Hi, I sold an '03 Limited (big mistake!) and just bought an '07 SR5. I want the grille to match the paint, but my dealer claims he can't find a part number for it. I know it exists on the '07 Limited so they have to be able to get them. Any ideas from anyone on how I can get one?
I think you can buy em from toyotapartszone.com already color matched, if not you could have your current grille painted by a body shop. Not sure which would be cheaper.
Someone commissioned me to build one for them but sold their 4runner before picking it up so I've got a shadow mica grille for sale here
I can change the color for about $25 to another factory color or black for free.
fs: 4th gen satoshi grille
It would probably look pretty good, close to the same as a blacked out one, except that the shadow mica is a nicer black because its not just plain black. But I still think silver would probably look best.
As I said I can paint it silver for about $25-27 depending on the price of shipping for the paint from ATU. I could use much cheaper Duplicolor OEM match as well but I had a member tell me the silver looked a little green compared to his stock silver
I can also paint it any other color you want for the price of a can of whatever that color is.
These grills are looking great! Hope I'm still on the list, cause I'm getting anxious as to when I could get on.
Keep up the good work.
Draft version of satoshi
cutted to much at sides - be carefull
Lamps will be a bit removed from center and a bit lifted
Hella Covers will be painted
