md4runner said:
Hey Gang...Help!
I'm having problems with my '03 Limited 4Runner...A couple of days ago, I couldn't get the truck out of Park...The truck starts fine, I put pressure on the brake and try to shift into Drive...I have an automatic transmission, and it didn't want to budge...After a couple of minutes, I slammed my foot down on the brake pedal and I was able to shift the car into drive...Then the VSC TRAC, VSC OFF, and ABS lights lit up on the dashboard...The lights went off after about a minute or two...
Has anyone had this problem?
Well, not exactly that problem. But, here's what happened and what I learned from it.
Been driving this '04 Sport for about a week now since getting the tags. It came with 23k miles of experience with a younger man.
Short trip at lunch today and the battery light comes on. ... Uh Oh! ... Then when I get back and turn it off, I decided to try it again. Started OK, but now no battery light, but VSC TRAC, VSC OFF and ABS warnings all lit, and the radio is dead and I can't shift out of PARK! (PANIC! ... no, not yet)
Started checking fuses. Has to be sensor related. It's starting to rain, too. All fuses inside look good. Goes outside and removes cover from fuse box. There I see that one fuse has been smashed from the top and the 2 inner metal prongs have been beat down together so that they touch. Further investigation revealed that this was indeed the 140A Alt main.
I had no spare 140A fuse. I needed to re-establish the previous moron's temporary solution, thereby continuing the legacy. I had to beat on the already bent metal prongs some more to re-establish a good connection, which cleared all the warning lights and let me get out of park. The CD player was now working too.
Decided to make the drive to the nearest Toyota dealer's parts department. It was about 10 miles away in heavy stop and go, sprinkeled with rain. They didn't have one. I soon learned that the auto parts places don't have them either. I also learned that my temporary fix was more temporary than I thought. The battery light had come on again before I reached the second auto parts place. When I tried to leave, my shifter was now stuck in PARK.
Kill the engine; Pop the hood and fuse box lid; tap...tap...tap; Fire it up; Warning lights OK? (OK.); Button up & go.
That is where I stand now. Can't order a new fuse until Monday. Can't have a dependable rig until the fuse arrives ... whenever!
I didn't mean to hyjack your thread, but it looks to me like we may have a similar (not the same, but similar) problem. I hope this information helps you solve your mystery before you end up under the hood in the middle of nowhere in the rain.
