skiwindjunkie
Guest
My sunroof opens but when closing it goes halfway and kicks back. The only way to help it shut is to pull down on the roof when its closing. Dealer #1 said that I was missing a part, the left rail. They ordered it and I went back for install. They came out and said, they found the original rail in the track & had popped off. So I did not need the part. They snapped the original one in and tried. The rail snaps off upon closing and jams. They said that something is lodged in the roof and need to take off the headliner to investigate. (4hrs x$70) I said, yea right. Why didn't the first tech see my old rail in the roof, but the second tech did? DUH? I took it to Dealer #2. They said that I need new rails and cables. The cables are jamming at a cost of $2K. Runner is 4 years old with 61K and already I'm pissed. So help. I plan on calling my Toyota Extra Care Platinum Warranty to see if it is covered to have the rails & cables replaced. The warranty says it will cover mechanical failure and has no exlusions listed about sunroof. It does say that sunroof guides & channels are not covered in the gold plan, but nothing to the effect in the Platinum...pray. If they do cover it, then the headliner needs to come off...RIGHT? So should I address the TSB of headliner noise while they are in there? If it is not covered under warranty, should I risk just paying to take off the headliner to see if something is causing the rail to jam, or have it cleaned & lubed? If they get in there and that is the case, then it cost way less. I am not feeling that the short term route will solve the problem. Dealer #2 is more reliable and has stated that they have done a couple of rail/cable replacements, so they have seen the problem already. I have all my service done at dealers & also have three invoices showing that the sunroof had a special lube put in it to keep it greased. Any experience with the problems or any suggestions would be very helpful. Bottom line is the battle with the Toyota warranty.
