'05 SR5 2wd sits higher on the passenger's side?
Overkill
Every time I look out my office window I swear my 4Runner sits uneven, so today I finally went out and measured it. It is indeed 1/4" higher on the passenger's side in the front and rear measured a the top of the wheel arches. The suspension is all stock to my knowledge, and it currently has 122,000 miles on it. Is this something I should be worried about?
I've heard of this before, I think its normal...A quick search might provide some better info but I think your pretty much screwed unless you change you suspension setup
From what I've read, the drivers side sits lower because the battery is on that side, you sit on that side, and IIRC, most of the gas tank is on that side too. Not 100% on this, but I believe that was most of the items that made the weight greater on that side.
You can get a 1/4" - 1/2" spacer for the drivers side to compensate for the "lean"
Hope that helps.
Thanks, guys. I was mainly worried there was something wrong/broken. Sounds like it's just a normal thing. :bigok:
allcarhistory
