Formidable
Member
First of all, I am a huge retrofit fan. I did genuine morimoto 55w HID retrofits on my 02 sport edition. Also did 55w morimoto HIDs with upgraded projectors and lenses on my 14 limited edition. I now have an 08 V8 limited and picked the following LED bulbs up for shits and kicks... I am VERY surprised. See pics below. Of note the 25 foot garage shot is at a left slope and obviously uneven background. When I come across a straight wall will take a pic. It’s pretty obvious the cut off is fine. Huge improvement over stock. Light is uniform and wide. No hot spots or squirrel finders with 06+ projectors. Five minute install. 100% plug and play, (pull and rotate the plugs in the connector if it doesn’t fire up). Instantaneous max output and color with ignition. No waiting for these to warm up. Highly recommended for 06-09. Best bang for the buck at $29.99. As good as my prior HID set ups that cost hundreds more.
For the 03-05, you will need to swap the headlights out for 06-09 with projectors before proceeding with these bulbs. Too much scatter otherwise.
I HAVE NO AFFILIATION WITH ANY OF THE FOLLOWING SELLERS. This post was made to give back to this community.
Auxbeam LED Headlights F-S2... https://www.amazon.com/dp/B01KFBPDAA
Multiple requests for links to my exact headlight and LED setup including low beams, high beams, DRL with turn signals: Make sure to cross reference and order the correct bulb sizes as some of these vendors apparently have drop down menus and run out of stock from time to time
-DT MOTO Blackout headlights
https://ebay.us/PLo3G1
H11 Low Beam: https://www.amazon.com/dp/B01KFBPDAA
9005 High Beam: https://www.amazon.com/dp/B01KFBPAJO
9006 Fog Light: https://www.amazon.com/dp/B07JVK1XFS
1156 Front DRL/Turn Signal: Out of stock! Make sure to contact seller prior to ordering.https://www.amazon.com/dp/B07FK67F2G
7440 Rear Turn Signal: https://www.amazon.com/dp/B074RLJMWQ
921 Reverse Lights: https://www.amazon.com/dp/B01I3OTWQ2
