06 sport v8 towing 23ft trailer
mud
Iam looking to purchase 08 jayco23ft hybrid to tow with my 4runner. Time to move up from the pop up. Anyone towing any thing like that with their 4runner. If so how does it handle it. gvwr about5000 lbs.
You should have no problems towing that camper I tow a Jayco 19H with my 06-V6 4runner I figure about 4,500lbs when full and it does better than I expected.
Make shure you put the auto trans in 4th gear on anything other than a flat road and on long hiway hills you may want to drop it in third gear and let her spin a little. It's better to hold a gear then to let the trans keep shifting from third to forth gear.
Make sure you have a good sway control on your hitch and run the tires with about 5 to 10lbs up from normal when you tow. I found the stock Dunflops a little squirmey with 32psi so I ran them at 40psi and it was much better.
I have a 20ft Weekend Warrior Toy Hauler....GVWR 6500lbs and the 4Runner tows it great but like Camprunner says leave it in 4th and make sure you have a good WEIGHT-DISTRIBUTING HITCH SYSTEM and sway control....
I tow a 26' camper with my 2007 V8 AWD Limited, no problem at all. Though I wish it had a bigger gas tank to extend the range between fill-ups (I get 10-12 MPG while towing). Dry weight for the trailer is about 4400 pounds, and I weighed it at 5400 pounds loaded on a truck scale. Most of my towing is in the Colorado mountains, from 7,000-11,000 feet altitude.
I use a Hensley Arrow hitch to eliminate the trailer sway. Not cheap, but makes life a lot easier and safer.
Okay, so it's not a 4Runner or an RV.....but it is the only type of trailer I have ever had to pull. It is a 53-foot Great Dane "dry van" trailer, and the tractor is a 2007 Sterling with a Mercedes 6-cylinder turbodiesel and a ten-speed manual transmission. Unfortunately, that (then-new) Sterling went to another driver and I typically drive a 2004 International 8200 or a 2008 tandem-axle Sterling straight truck -- both with Cummins turbodiesel engines.
Oddly, I would probably have a much harder time trying to drive a 4Runner pulling a camper than I do with a tractor-trailer.
:wtf:
-- PHOTOS ATTACHED --
2007SterlingExterior3.jpg~original
2007SterlingExterior2edited.jpg~original
$600 to fill both tanks!!
davebas
