10 offset to 15 offset "will it rub"
Matteblack
Member
I am looking to sway a 17x8 wheel with 10 offset to the same size but with 15 offset. I have a 3" lift with 285/70/17 tires and I'm wondering if the tires will rub on the UCA's? Thanks in advance!
I think you'll just have to measure and see. Do you have 5mm between your tires and your UCA? If not you'll rub. If you do all good
Great, yeah I have about an inch. The place that will do the wheel swap said they are still 50/50 on whether it will fit. Something about how the tire will fit on the new wheel is unpredictable.
AndiGarage
