11.2 mpg avg after lift. ride height question
interesting...will try it out thanks!
ebg18t i put 44psi in just to try as per the chart in you link and truck feels much more stable with handling.. Thanks for the info!
will see how the chock trick does with 44psi
Thanks all...
Thanks all...
Let us know how your mpg looks after a few tanks. I need to check my psi this weekend as my tires seem to lose a few psi every month or so. This set of BFG's seem to seep some. More so than others I have run in the past.
I do not have a scangauge...
A key component of getting accurate scanguage results is an accurate vehicle speed. You have to calibrate it to the speed you're actually going, or you'll get results that are skewed. There's a screen in the scangauge that allows you to do this, but it doesn't actually change your speedometer.
