110V/cigarette lighter adapter
dendad
I'm considering the use of a 110V adapter that fits in my cigarette lighter plug. Has anyone had any experience with this? I would use it for a cell phone charger and possibly (in an emergency) for a small electric blanket if I get stranded in a snow storm. Is it safe? I have a 2005 4-Runner. Thanks.
thay outlet is either 5 or 10 amp, an electric blanket may be higher than that. As a rule of thumb, just check the amperage on you outlet fuse, and check the amperage of the device you want to plug in, if it is below the 12v outlet you should be just fine.
Thank you very much!
You'd be better off with the 12V blanket from above. It's way more efficient than converting 12VDC to 110VAC. Either way it's going to be a big drain on the battery over a multi-hour period. Just get a down sleeping bag or something.
I have been looking on sites for a good electric blanket and this one below doesn't have good reviews. With cold weather coming, would need a better one than this. I drive a big rig, so
12v. isn't a problem or worried about running out of electrical power, have 4 batteries.
Amazon.com: Roadpro 12-Volt 100% Polar Fleece Heated Travel Blanket: Automotive
pax at 4
