westwind77
I found a 3 way
D) 12v power supply that works perfect in my 4R!
It is the "Wagan EL9794 12V 3 Way Socket with Battery Analysis" off amazon for $9.94 + shipping.
It has a long cable (way longer than needed) that plugs into the 12v outlet in the dash, the unit itself fits perfectly into the little 'shelf' below the 12v outlet. Actually there is space to spare, that is where the extra cable is tucked away. I am sure those who like taking part the dash could run the wire direct to the plug on the back side and keep the unit in the same place, giving you 4 full 12v outlets for your access! As always, threads like this are worthless without pics so here you go....
I'm sure there are a lot of makers out there, some might even fit a little better, but this works perfect for me, so I thought I would share!
