17 inch Taco wheels on a 99 ltd
Avarice
Hey, I've been around the forums for a while now but I'm more of a reader than a poster so I haven't bothered to make an account till now.
I tried to use the search and look through the forum as I'm almost positive I've seen people ask this question before. So I apologize for being redundant.
I know a guy that has a good deal on a set of 17" stock rims off a 2010 Tacoma. Running 265/65/17 rubber on em.
other specs he gave - 17x7.5 back space 5.4" o/s +30mm -
bolt pattern 6x139.7 or 6 on 5.5
So I'm just wondering if I could run these on a stock height 1999 t4r limited without rubbing issues or needing spacers etc. Ideally just a bolt on affair. Or, what I'd need to make it work.
Looking to pick these up for summer rims and keep my stocker 16's to throw my michelin aplins on for this winter.
This isn't the guy, but these are the same wheels -
69429 TOYOTA 4 RUNNER TACOMA 17" FACTORY WHEELS RIMS: eBay Motors (item 150512385830 end time Oct-30-10 16:31:14 PDT)
Thanks for any help, and hello to all you fellow 3rd gen owners. :hello:
you should be able to, only use 265/70/17 so its the same tire height as before. I dont see any problems with the width if its 265 which is on my 4Runner
you should be good to go as long as the lift and tire size remain unchanged...once you get wider tires and lift it, you might have some rubbing issues with the Upper Control Arm, but for now, you're gravy!
workingwheelswnc
