17x7.5" FJ cruiser oem steel wheels
Love it man !! So unique and different . I’ve been considering buying the Fifteen52 Analog wheels for my truck.
What lug nuts are you running with those? When Discount ruined my TRD wheels, they gave new new tuner splined lug nuts to go with the new rims and kept the old lug nuts. I doubt those will work on the OEM steel wheels.
How are these different than our OEM spare wheel? I was just thinking about running 4 of our spare steelies. They fit my 255/75 mud terrains without issue and look cool
That is what I am going to use- 4 4Runner spare wheels. From everything I could find, our steel spare wheels (#42611-35430) are actually 7.5" wide. As long as you use 4 of the same, it shouldn't be an issue. I already had 2 extra spares, so buying 2 more was the way to go for me. Wheels And Caps has reconditioned FJ wheels for $55 each, which is a bargain.
Looks great!
I wonder how these would look powder coated in a dark bronze finish..
Edit: Found this
Looks great!
They look great in white, that Massey blue-grey, black and probably a lot of other colors. The problem is that blasting and powder coating adds up quickly, so you are near or over the cost of many alloy wheels.
Toyota Part # 4261135330 on ebay.
There are mint pre owned ones for $280 shipped for the set.
OEM Toyota.
Got a black set and the powdercoated ones
One advantage of a steel wheel is that if its damaged it can more easily, likely be repaired than an aluminum wheel.
I have seen people beat one back into shape on the trail after a hard hit.
I looked thru several threads but didn't see an answer to this question. What lug nuts are being used with the FJ Steelies. Part Number? :noidea:
Are you using the original equipment metal tire pressure sensors? Or did you switch to a rubber valve stem tire pressure sensor (o.e. or aftermarket)?
Crookedcat
