1997 Clear Corner question - stopped lighting
heyoceanfloor
I'm not all that handy, but I decided to replace my stock corners with clear corners.
Here's the confusing issue (for me). I took both corners off, leaving the original bulb housing (the newer ones didn't quite fit the harness). I then screwed/locked the OEM housing into the new clear corners without issue. Should work, right? All the 'electrical components' that worked fine on my drive home from work haven't been changed (just taken out and put back) - but neither turn signal works!
Any ideas? I haven't tried cleaning the contacts yet.
Deno91
