1997 SR5 4X4 5spd/Manual NEEDS REPAIR AUSTIN TX
the-magic-man
Updating post with pic and CL posting
1997 SR5 4X4 4runner 5 Spd manual - cars & trucks - by owner -...
I have a 1997 SR5 4X4 with 5spd manual
Reason for selling is basically I don't want to keep putting money into it. Lots of upgrades.
Just drove the car here from CT. 2000 mile drive it held up well.
Known problems.
1. input shaft on the transmission is damaged. It will eat through the pilot bearing if not addressed in the future. New input shaft is $400 in parts.
2. Transfer case is leaking. Still functional.
3. The valve cover gasket is leaking. Does not need to be immediately addressed.
Car is still drivable. It has a new clutch that was just put in.
The interior has some wear. I have detailed the car multiple times including cleaning the headliner and all the vents.
4x4 works. Tires are 60-80% tread. Spare changed recently. Tires rotated and balanced recentlyOil changed every 5,000 miles.
Work list
Engine:
-New timing belt, accessory belts and water pump
-New rear main seal
-PCV catch can installed
Cooling/Heating
-Koyo radiator
-New heater core
-New heater control valve
-New heater hoses
Transmission
-New clutch and throw out bearing
-New Pilot bearing
-New clutch fork
-New flywheel
-New Tom Woods drive shaft
Steering
-New Steering rack bushings
-New left tie rods
-New steering wheel
Suspension
-New Toyota front control arms upper and lower
-New upper and lower ball joints
-New Toyota rear upper control arms
-Rokman rear lower control arms
-Rokman adjustable pan hard bar
-OME 2" Sport Shocks and Springs
-New Toyota sway bars and end links Front and back
Exhaust
-Cat back exhaust and O2 sensors
Misc
-Compustar alarm
-Sound system
-CBI Skid Plate
-Tundra brakes
-New battery
-Changed some of the interior lights
Parts that haven't been installed
-Savage offroad rocker panels
-CBI rear skid plate
Asking price is $4000
patnewton
