1997 Unable to read oil level
jetguy23
Hello all I'm first time user of the forum and this form of communication in general I think this is very kewl. Would someone can share some knowledge with me and help me with this problem. Five years ago there was a major issue that caused an engine to be replaced on my 97 Toy 4 runner 3.4 (Running the engine w/o oil). Long story short I bought a used engine from an 03 Toy 4 run and oil dip stick was repositioned to the other side of the engine. My buddy repositioned the dip stick because of the 03 engine configuration wouldn't allow me access to verify oil quantity on my truck (97) without be moved. Engine was installed, oil was serviced when we realized the dipstick wouldn't measure the oil quantity. I later removed the oil pan to inspect what was causing the stoppage of my dipstick entering the oil tank. Regretfully I did not resolve the issue.
I have been operating this truck for 5 years now with my theory of adding proper oil quantity at oil changes and verifying no oil leaks are evident around oil pan etc. my oil quantity is OK. Selling the truck now and DO NOT want to sell it without resolving this issue and definitely don't want to hide it from the potential buyer. Any insight will get all expense paid trip to Vegas and a hand shake from one of the last honest people around now a days in Vegas lol. Thank you for reading this post.
I would explain to the new owner your problem and let them decide. It won't hurt the resale value because the value was hurt with the replaced motor.
As for the motor. They stopped making the 4runner with the same motor in 02 so I am not sure how they put that motor into your truck. Now they did keep that motor in the tacoma till 04 but the oil chk tube was in the same spot.
Tell the new owner to change the oil diligently and keep an I on any lights that may come on. If the oil light comes on, it means that the oil pressure is low and needs to be corrected (assuming that the engine swap was done correctly).
Would a wire dip stick work?
I'm sure something could be fabbed up, then you could mark the lines where it's full, and one liter (quart) down.
Exactly what engine is in there? Pictures would solve a lot of problems here...
Your 1997 originally had a 3.4l 5VZ-FE with the dipstick on the driver's side.
A 2003 4runner had a 4.0l 1GR-FE with the dipstick on the passanger side.
Even a 2003 Tacoma had the same 3.4l 5VZ-FE with the dipstick on the driver's side.
I'm confused about what swap you have.
Dont worry about the dip stick, If you have a 4.0L in their, I am sure you will have plenty of interested buyers including myself!
Post up some pictures!
