1998 Toyota 4runner limited alarm system light is broken
Gatlin247
I have a toyota 4runner limited 4X4. I have been turning the key and pushing in the alarm system light in at the same time. But now I can't do anything with that truck because of the alarm system. Please help me!
What? There is no factory alarm button that needs to be pushed when starting the truck. Are you talking about the sensor near the e-brake? That's a glass breaking sensor, and probably doesn't even work anyways.
Toyota only put passive alarms in 4runners. So if your truck won't start because of an alarm issue, it's not factory and unless you can figure out what alarm and where it's at, I doubt anyone can really help you. You need to provide more info as to what's going on.
It'll be an aftermarket alarm.
Post a pic of the button that you push.
Usually, if your pushing a button while turning the key, your putting the car into valet mode.
Other option, find the alarm brain unit either under the seats, behind glove box or behind front seat kick panels and just unplug it.
If it is an aftermarket alarm then the starter kill is active and not allowing the starter to engage, and simply unhooking the brain, most of the time, will not solve the problem. You will have to drop the drivers side dash and look near the ignition key cylinder/ or stering column. Depending on the year of your Runner The starter wire will be 96- Black with silver dots, 97-98- Black, 99- Green with black stripe (or solid Green), 00-02- Green with Black stripe.
This wire will be cut in half with both wires going into a relay (usually tied to something under the dash near the stering column) If you see this then simply cut both starter wires off the relay (key side and starter side) and attach them back together and eliminate the relay. At this point when you crank the key the power from the starter will free flow to the starter instead of going through the relay.
Hopefully this was helpful.
I was just going to post this evening to ask about installing some type of alarm (and maybe keyless entry) on my '96 4Runner, so thanks for posting this!
give me the year of the T4R and i will get you the vehicle wiring for an aftermarket alarm, keyless entry, or remote start when i get to my shop tomorrow morning.
I have a 1996 SR5 5-speed with e-locker...
your in luck as my password and login works from my home computer. Here is basic radio and alarm info for the 96 T4R. They do not designate different trim as SR5 and limited are wired essentially the same.
Being yours is stick, remote start is not recomended because you would need to bypass the clutch to start, but all other alarm and keyless featres should work fine.
Good Luck!
Battery BLUE/YELLOW (+) RADIO HARNESS
Accessory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Power Antenna BLACK/RED (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) VIOLET
RF Speaker (+) LIGHT GREEN
RF Speaker (-) BLUE
LR Speaker (+) BLACK
LR Speaker (-) YELLOW
RR Speaker (+) RED
RR Speaker (-) WHITE
Amp Location RIGHT OF GLOVEBOX
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Security
WIRE COLOR POLARITY LOCATION
Battery WHITE/RED (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/RED (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/SLV.DO (+) IGNITION SWITCH HARNESS
All Door Trigger BLACK/WHITE (-) BACK OF FUSEBOX AT WHT 3 PIN CONN
Trunk Trigger RED/WHITE (-) DRIVER'S KICK AT WHT 26 PIN CONN
Parking Lights DARK GREEN (+) BELOW FUSEBOX AT WHT CONN
Convenience
Headlights-Lo RED (-) AT STEERING COLUMN
Trnk Release N/A
Remote Start
Accessory 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS (TESTS AS IGN.)
Anti-Theft Descript NONE
Tachometer BLACK (-) AT IGNITOR ON PASS WHEEL WELL
Speed Sense GREEN/ORANGE (AC) ECM BEH.GLOVE,22 PIN PLUG PIN 8
Brake Lights GREEN/WHITE (+) AT BRAKE SWITCH
Reverse Lights RED/YELLOW (+) IN HARNESS IN DRIVER KICKPANEL TO REAR
Horn GREEN/RED (-) AT STEERING COLUMN
Modules
WIRE LOCATION
Module 1 ECM BEHIND RIGHT SIDE OF DASH PANEL
Doorlocks/Windows
Power Unlock RED/YELLOW (-) NEGATIVE TRIGGER
PowerLock RED/WHITE (-) DRIVER'S KICK PANEL
And I also found this one. I use both and physically check and test all wires before connecting to them.
TOYOTA 4-RUNNER
MODEL
YEAR(S
4-RUNNER
1996-1997
KEY
T-HARNESS
IMMOBILIZER
N/A
N/A
N/A
PART
COLOR
LOCATION
DIAGRAM
12 VOLT CONSTANT
WHITE (+) and WHITE/RED (+)
@ IGNITION SWITCH HARNESS
STARTER
BLACK (+)
STARTER 2
N/A
IGNITION 1
BLACK/YELLOW (+)
IGNITION 2
BLACK/YELLOW (+) or BLACK/RED (+)
IGNITION 3
N/A
ACCESSORY/HEATER BLOWER 1
BLUE/RED (+)
ACCESSORY/HEATER BLOWER 2
N/A
KEYSENSE
N/A
PARKING LIGHTS ( - )
RED/WHITE (-)
@ STEERING COLUMN HARNESS
PARKING LIGHTS ( + )
GREEN (+)
IN WHITE PLUG, FRONT OF FUSEBOX
POWER LOCK
RED/WHITE (TYPE B)
@ 10-PIN PLUG, LEFT OF FUSEBOX
POWER UNLOCK
RED/YELLOW (TYPE B)
LOCK MOTOR WIRE
N/A
DOOR TRIGGER
BLACK/WHITE (-)
IN DRIVERS KICK PANEL, HARNESS TO REAR OF VEHICLE
DOMELIGHT SUPERVISION
USE DOOR TRIGGER, (Requires Part #775 Relay)
TRUNK RELEASE
N/A
SLIDING POWER DOOR
N/A
HORN
GREEN/RED (-)
TACH
BLACK (AC)
@ IGNITOR or DIAGNOSTIC PLUG, See NOTES #1
WAIT TO START LIGHT
N/A
BRAKE
GREEN/WHITE (+)
@ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM
N/A
ANTI-THEFT
N/A
NOTES
NOTE #1; THE IGNITIOR IS ON THE PASSENGER SIDE FENDER WELL. THE DIAGNOSTIC PLUG
IS ON DRIVERS SIDE, TOP OF MOTOR.
LINK 1
LINK TEXT 1
LINK 2
LINK TEXT 2
thanks for posting!
BTW, the 5-speeds actually have a Clutch Start Cancel switch...
you're in luck, as my password and login works from my home computer. Here is basic radio and alarm info for the 96 T4R. They do not designate different trim, as SR5 and limited are wired essentially the same.
Being yours is stick, remote start is not recommended because you would need to bypass the clutch to start, but all other alarm and keyless featres should work fine.
Good Luck!
LF Speaker (+) PINK
RF Speaker (-) BLUE
RR Speaker (+) RED
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Security
Convenience
Trnk Release N/A
Remote Start
Modules
WIRE LOCATION
Doorlocks/Windows
I have a 98, same kinda issues. No crank, it has the valet button that sometimes lites up and other times doesn't. Got into some deep water and now the horns wont quit. Have one key with the alarm buttons on it and a key fob for it, neither one will work to shut off the horn and still no crank
Secutity light.
T
Good Luck!
LF Speaker (+) PINK
RF Speaker (-) BLUE
RR Speaker (+) RED
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Security
Convenience
Trnk Release N/A
Remote Start
Modules
WIRE LOCATION
Doorlocks/Windows
Hello my friend,
I have a 1998 4runner,I bought a keyless remote but i cannot program it because as i was told,the security light has to be bleaking in order to promgram it.but it's not.Any advice? Can email me at [email protected]
OP,
Please post a pic of said button and whatever else you have installed that coincides with the alarm.
I too have what appears to be a factory "security system". It's a black button with a small red light in the center with the words "Security Alarm" written on it in white letters. However, it never turns on but I also don't have the factory key FOB either so who knows if it works?
patnewton
