CharliePR74
Member
This is driving me nuts! I own a 1999 T4R, 199,500 miles on it. Very well taken care off. Never had any major problems with it till 2 weeks ago when all of a sudden I started it up and there was some misfiring cylinder. Up to date I've replaced wires, plugs, cleaned the MAF sensor, did an injectors service and thinks have only gotten worse! At some point it started blowing a lot of white smoke, but a lot of it! Doesn't matter if its cold or at normal operating temperature and happens sometimes and sometimes just nothing. Smoke smells very toxic, like gas. I even removed spark plugs and found most of them covered with what seemed to be gas (still humid). Today I replaced the upstream O2 sensor and also found it humid, same scenario. Still waiting for the downstream sensor as it was giving me some funny voltage values. I have gotten several codes, P0300, P0304, P0306, P0172, etc. After cleaning the MAF sensor, the P0172 disappeared but still getting P0300 and P0306. Swapped 4th and 6th coils and same story. Have also had code for bank 1 running too rich on fuel. I have read almost any forum on the internet and no one provides a true solution for this type of problem. Head gaskets? Could be but I see no coolant consumption as previously stated, no presence of water in oil (replaced it days ago when doing the troubleshooting),did a compression test having pressures ranging from 210 being the highest to 170 being the lowest. Coil packs checked and also injectors and everything seems to be fine.
Still to check, fuel pump pressure which doesn't seem to be the cause and coolant temp sensor... running out of options.
Any help from you guys will be appreciated.
Thanks,
CJ
Thanks,
CJ
