1uz swap
Stop right now! Use diesel! JK...this is pretty sexy. When you're done, give me your address so I can "Gone in 60 seconds" your Runner.
Awesome info tego!! I had always heard power specs were a lot lower, but I guess they were at the wheels or something. I still want one dangit, the cool factor would be up there for sure.
One of our goals was for no body/ suspension mods. And with the sc400 oil pan it fits perfect. 4x4 would prolly need a 4x4 tundra pan to make it work. But ours is 2wd. No no lift required. And everything stock will work including all the gauges.
Two wheel drive. Go ahead and make it 4wd.
Your engine must sit lower because of not having the front diff to clear.
Looks good. Can't wait to see it run. :snacker: You'll probably need to re gear because your using the 4 cylinder diff and get a posi diff to keep from spinning one tire.;):
Ambrose67
