20 inch wheels on LIMITED
This really chaps my hide! You spend $40k+ on a vehicle and then you have to replace expensive parts (wheels) to make it functional. The original Yokohama tires are garbage and are worn out at less than 40k miles. As best I can tell there are 3 tires available at the stock 245/60R20 size: Yokahoma Geolander G96B, Bridgestone Dueler H/T D684 II, and Bridgestone Blizzak DM-V1. None are attractive, particularly the OEM Yokohamas.
There are some other annoying design flaws in the 2010 2011 2012 2013 Toyota 4Runner. And yes I am trying to create search hits by typing in all the years.
Such as when you shift from reverse to forward it takes the ECU approximately 3 seconds to determine that it is indeed a car and should move when you press on the gas pedal. It's human nature to press the gas pedal down more when nothing happens, so when it does finally realize it's a car it takes off like a rocket. Toyota should have spend the extra $3 to upgrade the ECU to an 8088 processor.
And give me a HVAC system where I can select an infinitely variable choice of air direction and recirculation. And one which remembers where it was set last when you turned the car off.
This is my first auto trans. If you turn the car off with the trans in drive and then shift to park the car will not lock. You have to get back in the car and turn it on again. Very annoying.
It would be nice if they would put the microphone in the steering wheel. When using the bluetooth phone connection I have to yell at the top of my lungs. So I don't use it.
I had a shock explode in my garage. Maybe a freak occurrence? It took the dealer 3 appointments and 10 days at the dealership to get it fixed. Luckily it was under warranty.
And I have to say my vehicle drives like a pile due to excessive steering feedback. I think the current trend is to design in too much caster. Probably something the attorney's told them to do, but it works in reverse. A lot of caster does not result in a lot of safety. Maybe new tires will help. I suppose a vehicle with such a high center of gravity is never going to drive like a sports car, but I think there is significant improvement to be made in suspension design on this vehicle.
I'm thinking about unloading mine (2010 Limited).
Sorry!
We could not find any products of this type that fit your vehicle: 2010 Toyota 4Runner Limited. Please clear your vehicle selection to see all products, or select another vehicle to search again.
For those that have 275/60R20 AT tires do you believe this setup would work with Daystar 2.5" leveling kit. Daystar seemed to think hink this would not be a good setup for off road. I only plan on doing trails, nothing that would leave my daily driver at the medics.
My stock Geolanders were toast, so I just put 275/55/20 Goodyear Wranglers on the stock rims....the tire shop didn't think twice about doing it.
The look and the drive is night and day. Should have come from the factory like this....pics tomorrow.
Good to know. I want to put the Michelin LTX MS2 on my new 2014 that I ordered in the same size.
Installed Cooper Discovery AT/3 275/60R20 on my Limited rims. Also installed the 2.5" Daystar 9134 kit as well. My garage didn't do an alignment but am having a bad vibration over 55MPH. Any recomendations besides get an alignment? PSI is set at 40.
A good road force balance.
Color choice opinions with black 20" XD Addict wheels
I will soon be purchasing a 2014 SR5 for my wife, so no off-roading involved. We absolutely love the look of black 20" XD Addicts such as RiDE's (prior his current build), Orthoboy's, and Kingpin. The only problem is that my first color choice is silver and I have yet to see a silver with black 20" wheels. I think black is the best looking, but difficult to keep clean. Thoughts on color choices between silver, magnetic gray, or black with black XD Addicts, tinted windows, and 4 bilsteins(front at 0.85). Thanks for your input.
I have a Black Ltd with the Addicts and love them.....I like all your color options above but your choice.....wrap those wheels in something nice!
I have 9k miles on my 13LE 275/55 R20 Goodyear Silent Armor. Goodyear is discontinuing the tire but love the ride and performance so far. Looks like it should have when I ordered it. Curious if the added width will have any negative impact in winter driving conditions. Guessing the improved rubber will be noticeable regardless.
New user first post. Great forum. I have a 2013 Limited - first 4Runner after trading in my Taco this summer. Anyhow, yesterday coming back from deer hunting I had a complete blowout on my stock tires - that have less than 4600 miles on them. I'm thinking I'm going to try the 275/55/20 terra grapplers or the Mickey Thompson Baja STZs. I've seen folks that like the terras, but does anyone have any thoughts on the MT Bajas? Thanks.
Update- We've put around 5k+ miles on the tires and have no complaints. Mileage went down to 17.7 from 19.2, but that was expected. No rubbing nor issues at high speeds. I'll circle back on this when we have some rain and more adverse weather.
2 mpg drop because of tire selection?!?!? :dammit: Didn't realize something so small has such a large impact on the mileage. I was expecting low gas mileage, but im getting 22 so I am happy. Want to do a lift and tires, but do not want to dip below 18 at this point in time, now the waiting game.
To be fair, tire selection really isn't a "small" thing and can affect the mpg, handling, ride, and overall performance of the vehicle. Tire/wheel weight and rolling resistance are major factors in mpg.
Read a few of the threads here; I'm sure 1E has an exceptionally detailed explanation that someone later boiled down to two sentences.
I agreed, but, the 275/55/20 Continental CrossContact LX20's I ordered are made to fit a 7-9.5 rim. They're the only tire available right now that are "recommended" to fit the 7" wide rim of the LE's.
So, after reading through many pages of discussions about mounting 275/55R20 on the stock 5th Gen Limited Wheels, I just couldn't get over the fact that almost every manufacturer recommended a minimum of a 7.5 rim for that size tire. While I was/am interested in choosing a different tire than the 2 all-season OEM options for my 2011 Limited, I would prefer to mount a tire that was "approved" for the rim size. With that criteria set, I looked into the Continental CrossContact LX20 in P275/55R20 and found that TireRack approved them for a 7" rim as many other had stated. Then the engineer in me whispered "verify...", so I went to the Continental website and noticed that the CrossContact LX tires were approved for the 7" rim, but the CrossContact LX20's were approved for a minimum of a 7.5" rim. WTH?? http://www.continentaltire.com/www/download/tires_us_en/themes/light_truck___suv/highway___street/img/data_sheet_en.pdf
http://www.continentaltire.com/www/download/tires_us_en/themes/light_truck___suv/highway___street/hidden/printable_datasheet_en.pdf
I sent an email to Tirerack AND Continental, where Continental quickly responded with the following email:
"Continental tire rim mounting question
Discussion Thread
Response Via Email (Renae) 11/11/2013 03:47 PM
Dear Daniel,
[Web Inquiry: 131110-000007]
Thank you for contacting Customer Relations at Continental Tire the Americas, LLC.
The 275/55R20 should be used on 7.5" to 9.5" rims. This is a typo on our web site and Tire Rack's.
Sincerely,
Customer Relations
I had also asked Continental if the tire was not recommended for this rim size simply because they did not test this particular rim size, or if it was specifically restricted due to its size (as others have posted regarding sidewall stress and potential cupping issues). As I sort of expected, they kept their answer simple and did not respond to that part of the question.
I know that many on this board would love for this Thread to go away, and I also know that there are many 4Runners running 275/55R20's on stock Limited rims and very satisfied with their purchase. I was pretty comfortable purchasing the larger tires on the stock Limited rims thinking that there was at least one or two manufacturers that allowed a 7" rim with this tire size, but now that I know it was an error, I am less likely to deviate. I am now leaning toward picking up some 5th Gen SR5 or Trail 17" rims with snow (Blizzak) or AT (LTX A/T2 or something more aggressive and fun ) tires for the winter and run OEM Geolanders for the rest of the year.
I'm new here and have appreciated this site and its many members that have helped me become more familiar with my 4Runner. Thanks!
I went through the same thing a few months ago. While I'm sure the 275/55/20 tire would be okay from a safety standpoint, I was not comfortable with the possibility of premature or irregular tread wear. In addition, Discount Tire (A) would not install them and (B) would not warranty them. This made my decision that much easier.
I opted to dump the wagon wheel skinny 20's and picked up the Gen 4 Limited wheels. Brand spanking new for about $160 per wheel. Added some Micheline's and I couldn't be happier!
Don't know if it's a typo or not (may have been pointed out by someone else already), but the official product info from Toyota for the 2014 Limited with 20 inch rims says 7.5-inch rim. Sorry to cloud the issue, but it's what they sent out.
