20" Limited tire recommendations
the problem with simply telling him to search is that it fills the forum with this non sense and when people do search all they get is threads like this, or the OP is scared off and never returns for his answer.
now i dont own a 5th gen but 275/55/20 is available in a lot of manufactures and should fit fine. assuming you want to go larger than stock size tire that is...
5 years later, I Googled "Limited 4Runner Tire" and got this as a top hit. Nice foresight!
Sent from my Nexus 5X using Tapatalk
I've posted this somewhere else, but since it came up...
Cooper HT Plus are pretty quiet, smooth, CHEAP!!, and pretty decent tread for mild trails.
Side by side with a Toyo AT2. They're not as different as you might think based on the names and sales materials.
Pirelli Scorpion ATR
Just changed the stock 20 Limited tires to 275/55/20 Pirelli Scorpion ATR. Smooth ride and no rubbing.
I've been running these exact tires on my Limited for a few years, i have 40k miles+ on them and they look like i can get another 20k miles pretty easily. They are great in the rain, snow, and ice. I will buy them again!
Bumping this up to see if stock tires from a brand new limited would work on 20x9 with -12 backspacing. Tire size is 245/60 20. Thanks
Here are the Toyo at2 p245/60/20 mounted.
Limited tires
I put Bridgestone Dueler H/L Alenza Plus 275/55-20’s 111H on about a year and a half ago. Couldn’t be happier.., I’m very partial to Bridgestone’s, so shopped Revo II’s, LTH and 684 II’s. Also Michelin LTX..., but went with the Alenza’s. Also installed Bora 19mm spacers. Didn’t need to for any rubbing issues, just wanted to widen the track a bit and alter on road dynamics. Again.., very pleased with the results. I don’t off-road other than the occasional dirt or gravel road. A little in town but mostly freeway and twisty county roads. Very stable tire in wet, dry, snowy conditions. Quiet and smooth riding tire. I’ve been on freeways when it’s been raining so hard that people are pulled over on the side of the road and I’m cruising along at 70-75 with no problem. So, I’m full time 4WD, but this tire displaces water exceptionally well.
Going with this tire I did adjust pressures quite a bit from stock 245/60’s.
I’m running something like 40-41 fr - 36-37 rr.
I just installed good year wrangler 275x55x r20 on my 2015 limited with no lift. I just want to know if I mount the same tire on my spare will it fit in the spare tire wheel well? or where the spare tire is supposed to be in the car?
I installed a set of Bridgestone Dueler H/L Alenza 275 - 55 - 20 on stock 20"wheels. No rub, feels nice and smooth on the road. I won't be doing much off road so I am not worried about aggressive tread pattern for playing in the dirt.
My last vehicle was a 2007 4Runner Sport in white. I had Michelins with raised white letter outline on it. Looked great on a white truck. So I wanted to give it a try on this 2018 Arctic Blue Limited. Seems to be a pretty good combination.
Bumping this Thread for Snow
Hello, I am new to the forums and new to my 2022 4R limited. I know it isn't news that it is difficult to find snow tires these days especially in 245/60R20. I was able to track down some Nokian Hakks in 255/55R20. I see a lot of you are running 275/55R20, does anyone have any experience with this tire size on a 5th gen limited? Any reason I shouldn't use em?
Thanks!
thadjay
