2000 4Runner 3.4L V6 4x4 5 speed in Chicago
BLK_MAG1K
Great running 3rd generation 4Runner. Extremely reliable vehicle with great maintenance records. 218,XXX miles. Barley broken in for a Toyota.
New from March 2020 within the last 1000 miles
OEM clutch disc
OEM pressure plate
OEM throw out bearing
OEM pilot bearing
OEM slave cylinder
OEM flywheel
OEM rear main seal
OEM u joint
OEM rear brake backing plates
OEM rear wheel bearings
OEM rear wheel axle seals
OEM rear wheel ABS ring gear
Complete OEM rear brake overhaul (wheel cylinders,brake shoes and hardware,drums, parking brake bell crank)
New sway bar end links (front)
New fluids (transmission,transfer case,rear differential)
New OEM shifter bushing
New OEM blower motor resistor
All LED interior lighting (dash,climate control,map lights,dome lights)
Clean matching interior (all seats and door panels)
Within the last 3 years
OEM timing belt
OEM water pump
OEM timing belt tensioner
OEM idler pulley
OEM cam seals
OEM plugs and wires
New transmission mount
Remanufactured front brake calipers
Pads
Rotors
Coolant flush
2nd gen Tacoma wheels
Good tires
Price is OBO
Price is OBO
A starting price would be helpful. No point in getting a bunch of $500 offers if you're expecting $50k.
Do you have any undercarriage and frame pictures? Particularly the rear frame near the exhaust, both lower control arm brackets, and rear axle.
Also one of the requirements according to the sticky
B) All Threads must contain the following information
---1) What is for sale/trade (model, specs, etc.)
---2) Condition
---3) Price/What you want to trade for
---4) Location of item
---5) At least one picture of the item for sale or for trade
Rialm
