2000 Tundra TRD suspension, direct bolt on?
c0mmon
I think this is a stupid question but I could not find anything in the suspension
I know someone with a wrecked 2000 Tacoma TRD with blistens/suspension in great condition.
This is a bolt on? Offers a mild lift yes? Any concerns?
From what I remember, fronts yes, rears no.
You will need to adjust the angle on the front struts too, Taco front struts have about a 15 degree angle difference once bolted up from 4Runner ones. This can be solved using a large pry bar.
Pry bar=bending it? Please explain-
Okay, I can't find the picture that explains it so let me try.
Say you had an aerial view of the Taco front struts - if you looked at the back two studs on the top hat of the strut, you could run a straight line from one side to the other and contact all 4 studs.
On the 4Runner, those struts are turns inwards toward the center of the truck by about 15 degrees.
What this means is - if you put a Taco strut on a 4Runner, the lower mount won't line up, you need a large pry bar to turn the strut, or my preferred way, use a spring compressor to relieve spring tension and line things up before install.
makes perfect sense, does this compromise rigidity or is it designed for this type of movement?
alexaturner
