2001 4Runner Limited Thunder Clouds NY,NJ,CT
S2KMR
2001 4Runner Limited Thunder clouds $6,995
01 Limited 154K miles, bought it in 2014 with 149k, car is in mint condition. Everything works and run very strong, timing belt was done @90k per PO, Vins are on all panels, Things I had done after I bought the truck.
154K miles
All tires were replaced @152k
265X75X16 Kumho Venture AT 15
Alignment done with tires installation
All Fluids was flushed except Diff and Transfer
THERMOSTAT 90916-03075
TOYOTA OEM 95-04 Tacoma 3.4L-V6 Radiator-Water Inlet 1632162020
6 spark plugs (part# 90919-01192)
1 spark plug wire set (part# 19037-62010)
TOYOTA 8524235010 GENUINE OEM WIPER BLADE (All 3 blades)
TOYOTA OEM 96-02 4Runner 3.4L-V6 Radiator-Lower Hose 1657262090
TOYOTA 1657162070 GENUINE OEM FACTORY ORIGINAL UPPER HOSE
Toyota 4Runner T100 Tacoma Tundra Engine Cooling Fan Clutch Aisin 0892104950
All busing replaced with Energy, Suspension steering rack bushings too
K&N Air Filter
PCV Valve
Sylvania Silverstar ULTRA H11 Pair Set High Performance Headlight
Thing I I will include with the sales:
Genuine Toyota (04438-35060) Drive Shaft Boot Kit
Genuine Toyta Rear Drums Kit
TOYOTA 4RUNNER TACOMA 3.4L V6 5VZFE OEM TUNE UP KIT SPARK PLUGS WIRES PCV GASKET
TOYOTA 993642087078 GENUINE OEM AC BEL
TOYOTA 900809109083 GENUINE OEM ALTERNATOR BELT
TOYOTA 900809112683 GENUINE OEM P/S BELT
TOYOTA OEM 2330062030 Fuel Filter
TOYOTA TACOMA GRILL CLIPS X10(BAG OF 10) OEM FACTORY (90467-12040)
I have many many parts that I will include
Price $6,995 OBO
VW will be buying my TDi buy end of Oct/beginning of Nov
If for some reason you still have I will be interested. I know that is 6ish weeks from now
tyler_ross
