2001 Silver City NM $5,500
oneal48
240,000 miles. New ball joints, tie rods, rack and pinion bushings, control arm bushings, bilstien 5100's with eibach coils, radiator, starter,alternator, 8000lb winch, 265/75/16 cooper at3, custom front bumper. My number is 575-313-9114. I prefer text due to work but if you call and I don't answer leave a message.
This is a great vehicle with a toytec 3" lift. This vehicle took my family from southwest New Mexico to Northern California and back without issue. I use this vehicle as a daily driver. Besides some cosmetic issues it is a sound good running vehicle. It has been well taken care of in the time that I have owned it. $5,500 or best offer. Thank you for looking.
Bought March 27, 2015 @ 223,400 miles
@223,400 Replaced the transmission with a used transmission. New front pump seal, New transfer case rear seal, new transmission filter. New battery.
@223,892 installed rough country lift and new upper right ball joint.
@224,200 New rack and pinion bushings.
@225,600 New 265/75/16 Cooper Discoverer AT3
@225,850 custom front bumper with 8000lb smittybuilt winch. New front and rear oxygen sensors.
@226,850 new inner tie rods.
@230,300 new alternator
@233,670 new front breaks.
@233,810 new bilstien 5100 front struts with Toytec Eibach front coils (left the rough country rear lift in place)
@234,500 new upper and lower ball joints and cv shaft on the drivers side.
@235,000 new starter
@235,770 New radiator
@238,250 new rear breaks and rear wheel seal replaced.
@139,000 new upper and lower control arm bushings & new cv shaft and ball joint on the lower right side.
Catalictic converters need replacing.
erinobr2000
