2002 headlights are these cheapos dec?
I bought some cheapo headlights from amazon or eBay and I haven't had any issues whatsoever. Makes the truck look tons better. And if they do turn out bad, oh well it wasn't too much money wasted.
I think ill pull the trigger and be the guinea pig on this one. Worst case im out $60 and still have my stockers for backup.
All 3rd gen head lights got glass so they won't fog.
Keep in mind, some aftermarket lights may not focus well.
I bought set like this way back in 2010 and have not had any issues with them at all. 1999 2000 2001 2002 Toyota 4 Runner Headlights Corner | eBay
Are these right-hand drive or left hand drive? I would think JDM would be right-hand drive and have a funky pattern for US use. I also assume no DOT or SAE number on the glass?
I bought an Eagle Eye replacement (US-type) and the beam pattern was horrendous. I went and got an OEM from the junkyard.
Can you even purchase a aftermarket (non-OEM) headlight in glass?
Yes, my Eagle Eye was glass. TYC makes them, too. Depo, too, I think. (Certifit)
Yes, the Depo brand are glass. My headlight assemblies are toast and I just spent a couple weeks looking around before ordering these from Amazon:
Amazon.com: Depo 312-1142R-AS Toyota 4Runner Passenger Side Replacement Headlight Assembly: Automotive
I got them Friday, but haven't had a chance to install them yet. I took some before pics to compare, and I was planning on starting a thread about them since the subject seems to come up often here, but I'll just post in this thread instead once I get them installed.
I might have been able to get them a little bit cheaper somewhere else, but I've always had good luck returning stuff to Amazon if I needed to so I figured it was a safe bet.
From what I've seen in the past, the lenses are pretty good quality, but the housings are not very good. But I have seen people take the lenses from the new ones and mount them to the stock housings.
That's what I plan on doing when I do the projector retro.
I replaced my factory 99' style headlights with cheapo Ebay ones and I think they are pretty great
Granted the reflector surface on my OEM's was shot, so when I put in the cheapos it made a world of difference.
Installed the Depo brand headlight assemblies yesterday. Took some before/after shots, but wasn't sure how far to park away from the wall to get best results to compare.
The first two pics are from about 5 ft away, and the third is from about 12 ft away.
Before (close):
After (close):
After (back):
Side view before:
Side view after:
Didn't really do any aiming other than just lining the lenses up to be flush with the filler panel like they were with the OEM that I took out. The Depo that I bought came with bulbs, but I used the ones I had in the OEM for comparison (they are GE Crystal Vision, about 3 years old).
Clocktower07
