2003 4.7 - Replacing Radiator
Adutchguy
Hey all,
I was told by my local shop that my radiator has a slow leak, this was discovered while they were in the process of changing out the water pump, belts, seals, tensioner, etc...
Is changing out the radiator something a fairly noob mechanic could accomplish? And if so, what should I be aware of going into it? Any tips or tricks? Suggested parts? Any out of the ordinary tools?
2003 V8 4.7
Hey all,
2003 V8 4.7
To answer my own question. This IS something a noob can do.
+ Drain the radiator completely.
+Be sure to have something under the transmission cooling lines as these will likely leak a little trans fluid.
+ Be sure to have a set of pliers that you can use to open the clamps on the radiator lines. I used a large tongue and groove plier to do this.
+ Generally all you need is a 12mm and 14mm socket and a 6" extension.
+ You will need a little over a galon of fluid I used this from amazon (https://amzn.com/B004SL8568)
+ I got my radiator from the dealership. They wanted like $500 or something stupid like that for an OEM one. But the parts guy was like, "F that, don't buy our OEM. Get this other one for $156." I'm at work and don't have the exact part number. But just call your dealership and have them order one in for you.
That's all I got for now.
AndiGarage
