2004 CV joint question
woodster
I'm replacing my drivers side drive axle on a 2004 4runner and the repair manual is telling me to use a slide hammer with a hook adapter which is placed in the notches on the inner CV housing.
Amazon.com: OTC 27315 Slide Hammer Puller Hook Attachment: Automotive
A local auto parts store suggested using a CV joint puller with a slide hammer but the adapter does not fit around the shaft of the axle behind the inner CV housing. Just wondering who has replaced the drivers side axle and what methods worked best for removing it from the differential?
What worked for me for drivers and passenger side axle removal was to use a pickle fork tie rod end removal tool and wedge it between the axle and differential, lightly tap the fork in which will drive the axle out. If the pickle fork bottoms out before the axle comes out then gently pry it the rest of the way out. You can just rent (borrow w/deposit) the pickle fork from an auto parts store.
We used a piece of pipe and a 3# sledge..... Put the end of the pipe on one of the flats on each corner of the CV and hit the other end with the sledge.... Popped the CV right out....
