2005 Flasher relay location and how to change the front indicators and fogs?
Resistors didn't work for me either and the hyper blink is butt raping my rear turn signal bulbs
Don't know if you ever saw this, but it may be worth giving a shot. I'll get around to doing it eventually.
http://www.toyota-4runner.org/4th-gen-t4rs/144730-diy-flaher-relay-mod-led-12-pin.html
OP originally opened up the flasher relay and ground down the resistor, but then just replaced it with a couple .1 ohm 1 watt resistors in parallel to get the right resistance. Whitebeauty even chimed in on this thread. I made sure to favorite it for when I'm ready to give it a go. Should be a breeze for somebody with your skill set.
True true! I'm in talks with him right now as far as a fix but I like the idea. My only issue is the wiring cluster **** that's under my dash.
utkrstam
