2006 Solara Nav installation help?
ATL Newbie
This may be getting a little old, people asking for help on their navigation installation, so first I would like to thank all the people who have shared all of their work on the mulitple threads in this and the Sienna forum. The information has been excellent, and is the main reason that I decided to buy a 2006 4Runner without the JBL 10 speaker system and then install the Solara Nav.
I have the unit mostly installed, and will receive the XM radio hookup today. The Toyota Japan microphone should arrive next week. I currently have two questions:
1. First, does anyone have detailed info on installing and external speaker for the voice commands? I see that a speaker needs to be hooked up to pins 11 and 13 on the R5 connector, but I was just wondering if anyone had some step-by-step instructions?
2. This may be specific to the 2006 Limited model, but I was hoping someone would have some ideas. The 2006 Ltd comes with an auxilliary port built into the console. This port actually connects to the Radio through the 20-pin R5 connector, but it won't play in the 2006 Solara Nav unit. I guess the Nav Unit is not set up to accept whatever signal the aux. port is sending.
But my question is really this: My Factory radio already had a 12-pin connector that fits into the Navigation slot which people are using for the XM radio/CD changer/RSE connector. I was sure that my aux. port was using that 12 pin connector, but it isn't - when I pulled that connector out of my radio, the aux. port was still active. Does anyone know what this 12 pin connector is hooked up to in my 4Runner, and do you think I will lose anything if I unplug it and replace it with the XM radio connector???
install help 2006 4runner
the xm unit will plug into the black connector 12-pin directly below the 20-pin connector to the left of the radio. if you vehicle has rear audio that is where the xm will plug in. but you will lose rear audio in return
Thanks but maybe I needed to clarify my question.
I don't have the Rear Seat Entertainment system....but I did have something plugged in to that 12 pin connector in the back of my radio. I already put the XM radio in that slot for the navigator, and now the old 12 pin harness is just dangling in the dash, but I don't know what it was for?
Okay, I'll answer my own question. I'm not pretty sure that the existing harness was for the Rear Entertainment System, but since I don't have that system they wires just went to nowhere. No harm in having them still installed behind the dash.
Still waiting for further hints on installing that external speaker, though
I think you have pre-wired for the RSE or RSA, and thats why the connector is there... You can buy a splitter, if it makes you feel better to have everything plugged in!
j0
- I think the input is limited to only the E7007, and E7008 models which is the new Sienna and 4Runner navigations with bluetooth. I never saw a "input" on the either the Camry or Solara units.
j0
nav istallation
if you have steering wheel control, thats what the other connector is for and that will plug into connector under cooling fan
Clocktower07
