2006 Sport Edition V8 Revival After Broken Timing Belt
Very interesting. I’m surprised they can come out that way with the CATs being so big, but I guess there must be enough clearance. Do you reinstall the heads with the manifolds on as well?
Yes. The heads come out and go back in with the manifolds attached and tight
Wow!
Amazing job! I do simple mechanical work like change spark plugs, headlight projector retrofit, clean MAF, filters, take off the front/rear bumpers. I wish I had a buddy like you to learn more engine stuff, I would have loved to watch and learn from that project. You handled it like a boss. When my engine dies or whatever, I'm paying someone to fix it:)
Decided I needed to clean the Silver Beauty up a bit and get the 205k miles of grime out of it.
Stripping the seat covers to throw in the wash.
Clean Carpets going back in
Although the seats didn't really look dirty, I throw the covers in the wash, and was disgusted at the outcome.... That is just the Driver's seat covers in the washing machine.
My assistant helping to put the seat covers back on.
Right now, the passenger seat covers are in the dryer after their wash.
That’s awesome! In the first pic, is that black cover with the 3 screws, under the backseat area to access the fuel pump/sending unit? I’ve never had my interior apart so it would be cool to know if that could be accessed from above without dropping the tank.
That seat cover in the washer photo is very telling! And disgusting! I bet you’re glad you took the time to do that, if nothing else!
The pump would not fit through the hole in the floor. That is just a pass-thru for the electrical connector and access to disconnect it before dropping the tank.
You're a champ! That 4Runner couldn't have gone to a better home.
Selfishly, I'm super excited to have you around the forums here so we can bombard you with our shadetree mechanic questions.
Also, that scared the piss out of me to make sure I stay on top of that timing belt service schedule.
Amazing job on that! I rebuilt my engine as well, but just took the heads to a machine shop to fix the bent valve issue. Is it ok to just change the bent valves for new valves and skip the machine shop part on these engines?
Technically you can just replace the valves, as long as no damage was done to the seats or guides. I went ahead and and replaced the damaged valves. Redid all the seats and valve faces, and all new seals.
I would think twice about that. I recieved several quotes from several shops (most shops flat out said that the 2UZ was too hard to work on and refused to give me a quote at all) The dealer gave me a quote of $12,890, an independent shop gave me a quote for $9,400 and the rest told me to get lost or buy a different truck. I ended up doing it myself and taking parts to the machine shop.
How hard was it to get the seat covers off and back on? Do they just slide off? Mine could definitely use a cleaning, but I don't won't them to fit loosely if I screw it up.
They're not that hard if you are familiar with how upholstery is built and are familiar with removing and reinstalling "Bull Rings"
Nice project. That V8 should have plenty more life in it!
Thank you. I am confident this thing will last another 200k. The cylinders didn't show a smidge of wear, and had full crosshatch with no ridge. I had the oil pan off to retrieve a dropped cam cap bolt, and all looked and felt well down there, too.
This makes me so incredibly happy!! I just picked up an 06 V8 with about 180k. Beautiful runner and work!
They were hot tanked
How did you clean the mating surface on the block? I have seen a lot of different ways to do it, but when I did my headgaskets I used a yellow roloc bristle disc. I saw some videos on youtube that said not to use it, but I didn't run into any problems.
Used Parts cleaner and a razor blade. Should never ever use an abrasive disc or pad block or head mating surfaces.
