I have a 2008 4Runner and the brake pedal was sinking whenever I would come to a stop. Toyota wants you to change the entire Master Cylinder with a list price on the part being almost $3000!!! Plus the labor on top of that. Toyota does not list the part number for master cylinder piston sub assembly so I found a site that listed the master cylinder piston in a 2010 through 2017 and took a chance and ordered the part and rubber grease needed. This fix is a perfect match and the brakes feel like new again. You do NOT need to go to Toyota to bleed the brakes after. There is a really simple and quick way to bleed them which I will detail at the end.
Parts needed are:
Toyota part number: 47026-60090 Piston Sub-Assy
I also ordered the rubber grease for the seals:
Toyota part number: 08887-01206 RUBBER GREASE, 100G
The steps to change are as follows and wasn't as bad as I thought it would be for an average garage mechanic.
***NOTE The warning to disconnect the battery and wait 90 Seconds after disconnecting the battery or risk setting off the airbags.***
Once it's out you need to measure the linkage with a tape measure because you will need this when you put it back together. Pry off the rubber boot.
To get the piston out, you need to remove the C-clip retainer. The repair manual shows how to remove the c-clip holding piston seal
But I found a 3" piece of pipe worked like a charm in a big C-clamp. This removed the pressure off the seal needed to remove the C-Clip. Once the C-clip is out, simply give a good pull on the piston to remove it.
Apply the rubber grease to all the rubber seals and reassemble.
Be sure to set the length of the linkage correctly before you install it back in the vehicle in reverse order.
Before connecting the brake lines to the master cylinder, pump the brakes to move fluid to the brake line connector.
Once the middle two start to pushing fluid then follow the brake bleed process.
When I bleed brakes, I use a 3/8 clear hose run into a clear jar. Put the key in the on position causes the break booster to run, then break the bleeder on the front right and watch for air as you have your buddy touch the brake peddle. Then bleed the front left. Followed by the rear right and then left.
The process is listed in more detail here:
Message me if I've missed anything or anyone has any questions.
Parts needed are:
