2008 driver side turn signal out!
2Crunk
Hello All,
Iv been searching everywhere on here on how to replace the driver side turn signal/ drl. Iv got a 2008 sportedition and I was wondering if anyone has the part number for the bulb and or a link to a diy replacement. Im tryin not to go to the stealership for this problem but will if i must. thank you for any help in advance!
Did you check the owner's manual? I know that the manual shows how to replace the tail lamps, so I suspect that it also shows how to replace the front turn signal lamps.
m1911, no i havent checked that kinda slipped my mind, should have been the first place i looked haha.. thank you
chaz, thank you for the link and I didnt know it was that simple, but i think im going to have to remove the battery to access/ see everything im doing clearly.. did you remove your battery during your replacement process?
peacefulpiranha
