2010-2015 TRD CAI intake question
No changes from my 14' to your 16'.....it'll fit
and look like this:
Thanks Saker. I installed it last month and all the info on here was a great help. It really does have a roar above 5k RPM.
Just to satisfy my education, I read thru the other threads too but couldn't find an answer.
How is the TRD unit different from the stock airbox? both are in the same location and from my observation, pull from the same fender spot.
Why didnt toyota take advantage of the hood scoop?
The hood scoop is completely cosmetic and nonfunctional. If yours doesn't have one ask to see someone elses with the hood open. There is a company now making a hood with a functional ram air scoop but I haven't seen it discussed in here. Only a post about it on Facebook.
The stock hood scoop if converted to be functional, would probably have to grow in height to be advantageous. It gets tucked into the boundary layer pretty quickly and 'ram air' at these vehicles speeds is not a tremendous advantage to the engine.
The TRD unit looks very similar to the stock airbox, and the reason is that Toyota did a good job on the stock design. There are some tweaks to the airflow of the entire intake (fender well intake shovel scoop vs bell mouth, and some other tweaks). The tweaks in performance between the two designs are pretty much not noticeable except for acoustics.
I had a write up here: http://www.toyota-4runner.org/5th-gen-t4rs/85960-how-guide-trd-cai-installation-9.html#post1953275
Just so I'm getting the "picture" on what I'll have to purchase on my own if I go with the Camelback individual part purchase...
(1) Hose, 5/32” ID X 20” <-- #13 on the exploded diagram?
(1) Convoluted Split Loom , 15” <-- ???
(3) Nylon Tie Strap, Tree Mount <-- #19 on the exploded diagram?
(3) Nylon Tie Strap, 6” <-- #18 on the exploded diagram?
(1) Plug, Plastic Tree Clip <-- ???
All other necessary parts are included when you go with the individuals parts (other than silicone spray)?
Sorry to seem like I'm beating a dead horse on this, but I'm hoping to do this myself -- when my TE gets here -- and my OCD is kicking in.
Agreed, on US models the hood scoop does nothing. However could be converted to function for a top mount intercooler.
-A
This was taken from another thread where I posted the breakdown, the numbers I have listed on the side will not match the numbers in the fore mentioned diagram.....
If you buy the complete TRD CAI intake (PTR03-89100 ) for $400.00+-, you will get the following as described in http://toyotaparts.sparkstoyota.com/install/PTR03-89100inst.pdf
Part Number(s): PTR03-89100
Kit Contents
Item # Quantity Reqd. Description
1 1 Air Filter (P/N: PTR43-00083)
2 1 Upper Air Box
3 1 Lower Air Box
4 1 Hump Coupler
5 1 Throttle Body Coupler
6 1 Air Inlet Tube
7 1 Air Flow Accelerator
Hardware Bag Contents
8 1 #52 Hose Clamp
9 1 #56 Hose Clamp
10 2 #72 Hose Clamp
11 1 Plastic Nipple, 1/8”
12 1 Plastic Nipple, 5/8”
13 1 Hose, 5/32” ID X 20”
14 1 Convoluted Split Loom , 15”
15 2 Air Box Clip
16 1 Filter Minder Grommet
17 1 Filter Minder
18 3 Nylon Tie Strap, Tree Mount
19 3 Nylon Tie Strap, 6”
20 1 Bracket, Wire Harness
21 1 Plug, Plastic Tree Clip
22 2 Bolt, Socket M4 X 0.7 X 8mm
If you purchase this you will now have any use for #18 or #21, as the holes do not exist. You really don't need them if you have some zip ties to secure the wire looms as needed.
----OR----
You can purchase the following for about 235 shipped....
from Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
(TRD Air Filter Lid Replacement w/clips) TRD INTK FLTE LIDR PTR03-35090-AA $80.93
(TRD Lower Air Box Replacement w/clips) TRD INTK LWDAIRBXREP PTR03-35090-AF $63.35
(TRD Replacement Intake Flow Accelerator for CAI) TRD INTK FLW ACC PTR03-35090-AC $6.88
(TRD Replacement Intake Air Tube for CAI) TRD INK AIR TUBE RPL PTR03-89100-AA $29.69
(TRD REPLACEMENT coupler & clamp hardware kit for CAI) TRD INTK HRDWRE REP PTR03-89100-AB $35.42
(TRD, Air Flow Monitor, Cold Air Int) TRD GAGE INT TUN PTR03-34071 $19.50
It will not come with an oiled TRD Air Filter. Your stock air filter fits without issue. (Personally, I preferred not to run an oiled filter. YMMV)
It will not come with 15" of wire loom....cheap at auto parts store!
It will not come with 20" of 5/32 or 1/8" vacuum hose, also cheap at auto parts store!
It will not come with zip ties...IIRC, also cheap at auto parts store!
As described in this thread, a little O2 safe Silicone, and a small plug to seal a hole on the side of the air box and to seal a hole next to a mounting grommet on bottom of air box.
Silicone spray to facilitate inserting the tube into the couplers and you have just saved yourself $150.00
Hope this helps
Hope this helps
That was perfect! I'll be ordering the TRD CAI (and probably an AFE dry filter eventually)... got word that my dealer should be provided with my VIN next week. Hopefully within a week or so after that and I'll have it!
Thanks again!
Kit Contents
2 1 Upper Air Box
3 1 Lower Air Box
4 1 Hump Coupler
6 1 Air Inlet Tube
8 1 #52 Hose Clamp
9 1 #56 Hose Clamp
10 2 #72 Hose Clamp
15 2 Air Box Clip
17 1 Filter Minder
----OR----
Hope this helps
[MENTION=103267]Saker[/MENTION] Thank You Sir! Ordered the parts from Camelback per your post and saved the MONEY!
What you're pointing at is a baffling system that cuts down on noise.
Can you explain how those two boxes provide baffling? I’m being serious not meaning to sound like a smart ass. On a side note, I remember when I was shopping for one of my Tacoma’s and the salesman was explaining how a particular box off the intake was for evacuating water in case you suck some in.
Guys does this kit fit and can be installed for 2017 4Runner yet I have heard it does not is that true anyone on here for 2017 5th Gen ?
Thank you for the information. My last SUV, 05 Nissan Xterra, I did an airbox mod that really helped out the throttle response. Saw this and just finished the install. I did notice that the throttle response improved right away. As far as the rest, who knows. 16 SR5. Parts ordered from Camelback Toyota as listed before.
Installation Video
I bought TRD parts from Camelbak Toyota and wire loom, vacuum hose, silicon spray, silicon paste, zip ties from AUTOZONE & O'REILLY.
(1 of 3) TRD Cold Air Intake CAI Installation. 2017 4Runner TRD PRO Cement.
<iframe width="560" height="315" src="https://www.youtube.com/embed/WNR_ASVXbSo" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
(2 of 3) TRD Cold Air Intake CAI Installation. 2017 4Runner TRD PRO Cement.
<iframe width="560" height="315" src="https://www.youtube.com/embed/s0BjSytS20E" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
(3 of 3) TRD Cold Air Intake (CAI) Sound. BEFORE & AFTER. 2017 4Runner TRD PRO Cement.
<iframe width="560" height="315" src="https://www.youtube.com/embed/XslyCqmw50A" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
I can’t seem to be able to get the parts individually from the camelback Toyota website. Did they stop allowing this?
