roozter
No changes from my 14' to your 16'.....it'll fit
and look like this:
Thanks Saker. I installed it last month and all the info on here was a great help. It really does have a roar above 5k RPM.
and look like this:
Just to satisfy my education, I read thru the other threads too but couldn't find an answer.
How is the TRD unit different from the stock airbox? both are in the same location and from my observation, pull from the same fender spot.
Why didnt toyota take advantage of the hood scoop?
Your photo is showing the stock intake tube. That gets replaced with the TRD parts (#6 below):
What you're pointing at is a baffling system that cuts down on noise.
The hood scoop is completely cosmetic and nonfunctional. If yours doesn't have one ask to see someone elses with the hood open. There is a company now making a hood with a functional ram air scoop but I haven't seen it discussed in here. Only a post about it on Facebook.
Just so I'm getting the "picture" on what I'll have to purchase on my own if I go with the Camelback individual part purchase...
(1) Hose, 5/32” ID X 20” <-- #13 on the exploded diagram?
(1) Convoluted Split Loom , 15” <-- ???
(3) Nylon Tie Strap, Tree Mount <-- #19 on the exploded diagram?
(3) Nylon Tie Strap, 6” <-- #18 on the exploded diagram?
(1) Plug, Plastic Tree Clip <-- ???
All other necessary parts are included when you go with the individuals parts (other than silicone spray)?
Sorry to seem like I'm beating a dead horse on this, but I'm hoping to do this myself -- when my TE gets here -- and my OCD is kicking in.
It will not come with an oiled TRD Air Filter. Your stock air filter fits without issue. (Personally, I preferred not to run an oiled filter. YMMV)
It will not come with 15" of wire loom....cheap at auto parts store!
It will not come with 20" of 5/32 or 1/8" vacuum hose, also cheap at auto parts store!
It will not come with zip ties...IIRC, also cheap at auto parts store!
As described in this thread, a little O2 safe Silicone, and a small plug to seal a hole on the side of the air box and to seal a hole next to a mounting grommet on bottom of air box.
Silicone spray to facilitate inserting the tube into the couplers and you have just saved yourself $150.00
Hope this helps
This was taken from another thread where I posted the breakdown, the numbers I have listed on the side will not match the numbers in the fore mentioned diagram.....
If you buy the complete TRD CAI intake (PTR03-89100 ) for $400.00+-, you will get the following as described in http://toyotaparts.sparkstoyota.com/install/PTR03-89100inst.pdf
Part Number(s): PTR03-89100
Kit Contents
Item # Quantity Reqd. Description
1 1 Air Filter (P/N: PTR43-00083)
2 1 Upper Air Box
3 1 Lower Air Box
4 1 Hump Coupler
5 1 Throttle Body Coupler
6 1 Air Inlet Tube
7 1 Air Flow Accelerator
Hardware Bag Contents
8 1 #52 Hose Clamp
9 1 #56 Hose Clamp
10 2 #72 Hose Clamp
11 1 Plastic Nipple, 1/8”
12 1 Plastic Nipple, 5/8”
13 1 Hose, 5/32” ID X 20”
14 1 Convoluted Split Loom , 15”
15 2 Air Box Clip
16 1 Filter Minder Grommet
17 1 Filter Minder
18 3 Nylon Tie Strap, Tree Mount
19 3 Nylon Tie Strap, 6”
20 1 Bracket, Wire Harness
21 1 Plug, Plastic Tree Clip
22 2 Bolt, Socket M4 X 0.7 X 8mm
If you purchase this you will now have any use for #18 or #21, as the holes do not exist. You really don't need them if you have some zip ties to secure the wire looms as needed.
----OR----
You can purchase the following for about 235 shipped....
from Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
(TRD Air Filter Lid Replacement w/clips) TRD INTK FLTE LIDR PTR03-35090-AA $80.93
(TRD Lower Air Box Replacement w/clips) TRD INTK LWDAIRBXREP PTR03-35090-AF $63.35
(TRD Replacement Intake Flow Accelerator for CAI) TRD INTK FLW ACC PTR03-35090-AC $6.88
(TRD Replacement Intake Air Tube for CAI) TRD INK AIR TUBE RPL PTR03-89100-AA $29.69
(TRD REPLACEMENT coupler & clamp hardware kit for CAI) TRD INTK HRDWRE REP PTR03-89100-AB $35.42
(TRD, Air Flow Monitor, Cold Air Int) TRD GAGE INT TUN PTR03-34071 $19.50
Hope this helps
Guys does this kit fit and can be installed for 2017 4Runner yet I have heard it does not is that true anyone on here for 2017 5th Gen ?
Yes, I fit it in mine.
Thanks, Miller and what Kit did you purchase and did you install yourself?
I purchased the pieces individually as referenced above and installed myself.
Here's a good video:
https://www.youtube.com/watch?v=vnfLCHx_m8M&feature=youtu.be
