2010 4runner limited original tow hitch receiver
mbskoda
Does anybody know where I can purchase one? cant find it anywhere listed under toyota parts. Mine is all rusted . Thanks
You should just unbolt it, hit the rust with a wire brush and sandpaper then paint with rust reformer or some other similar product. If it rusted the first time, a new one will also rust.
thanks how hard is it to take it off?
Not any harder than replacing it with a new one, lol.
Not sure how much clearance you have but on my TE bumper it looks like you might be able to reach all of the bolts w/o removing any trim. The SR5/LE rear bumper might require you to remove the cover? Take a peek and see if you can squeeze a socket in there :)
thanks will try as soon as the weather gets little better, warmer.
The factory hitch has 4 bolts on the backside of the vehicle. You can see the lower two. Even with limited bumpers I was able to reach the top 2 with an open end wrench. It takes a long time to do it but it can be done. The bolts are really long and there is just enough give in the bumper skin to pull and get the bolts out.
