2010 limited fog light question. Loose as I push inward?
look171
I just notice my passenger fog light is recessed in a little and decided to push it a and see if its loose. It was, then I go and push the driver side and it was rock solid. I wonder what it can be? the outer side or away from the center of the car is still attached but I had to pick up my sister and take her to the airport so I couldn't crawl under to see it. Too dark now, but any ideas what's going on down there? Anything broken or it just came loose for some strange reason?
Note that there is only one screw holding the fogs in place...look there first. You don't have to undo a bunch of stuff to get access in there and look - I would just un-screw the fender inserts - roughly 4 bolts/screws per side in the wheel well - just move it aside to get your hand in there. The screw securing the foglight requires a philips head. Once you feel around and se that it is there, simply try tightening it, if not there I would remove the other side a get a matching screw to reinstall.
The fogs insert into slots, and then are secured with the one screw. Hopefully that helps.
