2014-2016 behind grill light bar mounts.
safe to assume a 22" led bar will be supported just as good as 20"?
A couple of guys in the thread have mentioned using a 22". I personally am planning to go with a 22" when I get around to actually buying my light...
Somewhere in the thread it was stated what the widest was that would work but I can't remember the exact #.
Yup 22" will fit no problem.
Brad brackets came in, look great...is there a possibility you could pasta quick tutorial on how to get the parts off to install with out taking the entire front of the truck off
Thanks,
77
Here is how I went about installing the mounts and light bar.
Remove upper radiator valence. Place mounts on aluminum X-member behind lower grill, bolt up mounts to light bar while behind the grill. Center mounts and light bar on aluminum bumper X-member. Use lower grill as reference to center the mounts and light bar. Mark holes with sharpie once centered. Remove bar and mounts from behind grill. From the back of the grill, unscrew the philips head screws on the lower grill retaining strip. From the front, pop lower grill free, and remove. Use body panel removal tool or flathead screwdriver with tape over the end to prevent scratching your bumper. Center punch marked holes. Insert drill from the front, drill 1/8" pilot holes (4), drill holes out using a 13/64" drill bit. Tap holes using a 1/4-20 tap once drilled. Pop lower grill back in, install retaining strip and screws. Now bolt up your mounts and install light bar. Lock tight and lock washers is highly recommended.
I've got everything I need for the install. Bar is mounted to the mounts, harness is run. I just need to find time to do it. I'll post pictures when its done.
Are these a direct bolt on? What bolts would I need?
Also I saw some people mention having it installed without taking off their bumpers.. How?
I thought I read in one of the earlier pages that they took the grill off. idk for sure though.
PRWhite
