2014 Limited bad U joints
Francis
Anyone else have to replace the u-joints yet? Mine is at 65k. Started making a slight "growling noise when heading down the road at 40+ mph.
I put her up on jack stands to check it out, to me sounded like a differential pinion bearing at first. Noise it makes comes off and on with the gas pedal. Pinion seems very tight with no play. Front U-Joint of the rear driveshaft has some play in it and so does the Rear u joint of the front shaft.
Not that 65k is not enough to wear some things out. Just curious if anyone else has come across this yet-
2014 Limited Bone stock
I would bet that you just need a proper lube of your propeller shaft, a lot of dealers don't do the job properly. There are lots of good instructions on here.
TerryNap61
