2016 Limited overhead monitor wiring question.
krosno3
I searched this forum, Youtube and Google and could not find simple enough and complete instructions I could use.
Long story short, I have to install overhead monitor in a place of old and crappy DVD player and since I'm not that good with understanding wiring diagrams I found great video on YouTube how to find door trigger wire but I have no idea where would be a safe place to tap accessories wire and 12v wire.
Any suggestions?
Why not use a fuse tap and tap into the interior fuse box? You can find a fuse that is only powered when the ignition is on so you will not have to worry about battery drain when the vehicle is off and insert the tap there. This also eliminates the need to cut/splice existing wires.
Any suggestions?
Hi krosno3,
perhaps I'm misunderstanding your objective, but is there any reason that you can't just use the existing DVD player's factory wiring to feed the new monitor installation, since the wires are already there?
rig, cheers
Hi krosno3,
rig, cheers
I bought an used 2016 Limited. Someone ripped out original DVD player that was installed there and dealer, just to cover cut-out in the headliner, put a piece of crap DVD player and did not wired it correctly. Instead of spending $2700 on a new headliner I decided to just get a monitor for kids which is not a bad idea after all for those long trips. Otherwise they keep staring into their phones..
I was able to find what I was looking for, thanks to some guys on this forum that tried to connect additional lights. I will try to take couple pictures when I'm completely done because Im still heaving some problems with a door trigger wire. Maybe someone will have the same problem trying to cover a big hole in the headliner and this solution is helpful.
Okay, ...think I gotcha!
If the DVD/CD player was dealer installed (most likely is), then I know I'm not gonna have the wiring schemes in my library for it. But you can still test each wire e.g., IGN HOT, GND wire... Please remember that our 4Runners are ALL 'Ground-side-switching' circuitry, which means it works the opposite from the cars/trucks of yesterday; the load (lights, fan, wiper motor...etc) is ALWAYS energized, and the switch connects the powered device to a ground source to complete the circuit!
So the HOT wire comes directly from the ign switch power source (Driver-side fusebox), and connects to the DVD's POS input terminal. The device's power switch (USUALLY) gets connected to the GND wire... but be sure to test the wires for their operation because we don't know if the installer followed the factory's wiring protocol!
Use a volt meter to test the wires for 12V HOT (connect the black lead to any un-painted metal body part). If one wire is HOT, keep it connected to your meter lead and reconnect the black lead to the other wires... "one at a time" until you see 12V's; there's your GND wire! Hope this helps, 'Best to you',
rig
Where is the YouTube video you mentioned that helped you find the door trigger wire? I don't know how to find it and haven't been able to find any info about how to find it. Thx
