KidVermicious
Well-known member
I'm no help with the vacuum lines, but you did test timing, right? If I had spark and fuel that'd be the next place I'd go. This trouble doesn't have to be related to the mudding, you know.
Are you getting fuel and signal to the cold-start injector? It's separate from the others, and can mess up all by itself. Just a thought.
Not questioning just trying to understand. I see you have fuel at the rails but you also said the plugs were not wet after an attempt to start. Did this get resolved? Are the plugs now wet?
Also the stupid Fuel VSV sends a signal to the ECM during ignition. See if plugging those lines does anything.
We put a noid light on the plus for the cold start injector and the light was solid for about 2-3 seconds then it turned off. I'm not sure if that is what it's supposed to do because the csi doesn't work like the other injectors. I do want to check more into the csi though. We need to test the cold start injector timer and the injector itself along with the associated wiring.
The first night we were trying to figure this out I didn't think we had fuel coming into the cylinders. After looking more in depth, I do believe we're getting fuel. We cracked a fuel line at the rail and tried to start it. We definitely have fuel pressure! A noid light test shows that the injectors are getting the proper signal for pulsation. After a few attempts of trying to start, the spark plugs smelled like gas so I'm assuming that we're getting fuel.
So as far as I know, we're getting fuel and spark. We're getting air. We pulled the #1 spark plug and put the crank at 5* BTDC and verified that the #1 piston is at TDC. We pulled the distributor and verified the ignition timing.
I am still interested in testing the idle speed control valve but cannot find any test for it. I did find stuff about the idle air control valve, is that the same thing?
So you're suggesting to plug the vacuum lines going to the VSV to rule out the fuel pressure vsv?
I too found the same thing on the idle air valve. I think when we attack this motor again we'll clean it up and make sure everything looks good on the valve.
I'm pretty much thinking at this point that we need to test every little sensor in the engine bay and make sure they're within spec and test the wiring as per the FSM to make sure the sensor is getting and sending the right signals.
If I understand that fuel VSV thing right the only purpose is to drop fuel pressure to the rail during low use conditions and to prevent "Hot Starts" Maybe the VSV is not allowing the proper pressure to the rail for starting?
If you plugged it at the VSV then it would not be able to adjust the pressure and the pressure at the rail would be at its max allowed. At least that is what is playing out in me head.
Make sure the oil is clean, no water or anything, just in case.
What exactly happens when you turn the key?
if you have spark, fuel, air and the engine cranks sounds normal. should do a compression test?
I think it's computer related. The immobilizer or something. It sounds like you have everything perfect and in running condition. Fuel rail has pressure, it's just the ecu or something is cutting it so there is no fuel being delivered.
Try unplugging the negative battery terminal for a couple minutes.
I'm not 100% sure what it is so I cannot disagree with you. But the noid light test says that the ecu is firing the injectors.
Dang. That's confusing.
Still I suggest you just unplug the battery for a little while. worth a shot?
Have you tried spraying some cold start in the intake ?
Starting fluid will go boom if you spray it onto sparky.
I would try some spayed in the intake.
