No comprehensive kit available. Here's a list of everything you'll need.
FIPG part# is: 00295-00103
2-Valve Cover Gaskets (both the L & R side are the same part), Part #11213-62020
6-Spark Plug Tube Gaskets, Part # 11193-16010
2-Intake Plenum Gaskets (both the upper & lower are the same part), Part # 17176-62040
16-Washer Seals (for the valve cover bolts) Part # 90210-05007
Camshaft housing plug(2): 11188-62010
PCV- 12204-62010
Grommet for PCV- 90480-18001
Included the PCV and Grommet. Replace that grommet while you have the VC off so you don't have to worry about it falling into the motor.
Didn't included the half moons. Just clean the up and put the FIPG on them.
Go to Camelback Toyota. They are the cheapest I could find and all the parts should be over $150 so you'll get free shipping.
Can I assume these will all work on a '01 SR5?
